Something a little different - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2011, 03:57 PM
hp246's Avatar
Had a bit of a different thought on a side glass window in a hardtop (actually a truck). rather than have the window function straight up and down, or make a slider as you might see in a drag car, I was thinking about making the window so that it rotates down into the door. The mechanism would be fairly simple with a hinged pivot point at the bottom rear of the window (Considering use of lexan). I would have to figure a way to latch the window at the upper rear corner, but was considering the use of a zoop type fastener.
Anyone ever try something like this? If so, did you encounter any issues with the install?
Old 02-19-2011, 04:06 PM
bigdog7373's Avatar
Of course it's fast
It wont pivot within the width of the door. It seems like it would be a pretty involved project.
Old 02-19-2011, 04:07 PM
poncho62's Avatar
Wiki Edits: 5
Depends on the shape of the window and opening.....Pretty hard to pivot a square window in that manner.
Old 02-19-2011, 04:12 PM
hp246's Avatar
This is a PU window. The vent window has been eliminated so the front edge of the window is cut at approximately a 45 degree angle, so it should pviot within the door. Since the door started out as a fiberglass racing door, no matter what I do to put a window in will be labor intensive. Thought about making a lexan frame similar to the ones you see on drag cars, but instead of sliding front and back, just dropping it down.
