Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Something is terribly wrong !!! HELP!!
Old 11-25-2004, 11:56 AM
rally4x4racer's Avatar
rally4x4racer rally4x4racer is offline
beer and time
Last journal entry: right after paint
more
need more info
does it only shake in 1st under load?
when in neutral or park does it do the same thing?
if its indicative of RPM you likely have an ignition prob, if its only in first gear then a tranny prob. my guess is you got on it while in fisrt and messed something mechanical up. (causing the problem only in first gear)
how old is the th350 and converter?
r4r
