sonic booms from sbc 350? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-04-2009, 03:34 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Originally Posted by h0trod389
im running a 389 in my 68 tempest, super comp headers, stainless 3" exhaust with delta 40's and a x pipe.
when im cruzing, and let off the accelerator, it will idle down and will emit a low but distinct "boom".
when i smash the throttle, she runs like a bat outta hell.
sometimes when cruzing on the freeway it will make other people look.
i tried to solve this problem by isolating plug wires, changing timing and even rejetting my carb...
nothing worked, it has a pretty radical cam in it ( 290 dur @ 050, with .525 lift 112 centers).
since it didnt hurt peformance, ive learned to live with it.
I wonder if in your case that could be an (after fire).. unburned fuel collecting and igniting in the muffler?
  #17 (permalink)
Old 05-04-2009, 03:39 PM
my "booms" are constant when cruising just off idle
  #18 (permalink)
Old 05-04-2009, 05:04 PM
machinist & fabricator
could be. but like i said, it didnt hurt anything so i never went any further.
only happens while cruizin without throttle. and at 700-1000 rpms.
anything above that, she growls.
  #19 (permalink)
Old 05-05-2009, 07:38 AM
83SILVRADO's Avatar
GROUND POUNDER
mine does the same thing... but its not a sonic boom... i have 350 with headers to about 2-3 feet of pipe to purple hornies. i cant hear myself think. but thats what i wanted.
  #20 (permalink)
Old 05-05-2009, 02:12 PM
its like a random muffled boom other than the exhaust sound. it is coming from the mufflers though.
  #21 (permalink)
Old 05-05-2009, 08:22 PM
Sounds like fuel lighting off in the mufflers
Shane
  #22 (permalink)
Old 05-05-2009, 08:57 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Exhaust backfires can be caused by several things, but I would check exhaust valves first. They might be sticking open/not sealing well. I would also check the timing chain. Usually they start making a lot of noise before they affect the valve timing too much, but if there is a lot of slack it can cause backfiring. Excessively rich mixtures can make backfiring, but you would probably notice black smoke.
  #23 (permalink)
Old 05-06-2009, 04:03 AM
i am running a gear drive. i dont think it is a backfire. doesnt sound like an explosion at all.
  #24 (permalink)
Old 03-17-2010, 10:20 AM
any other ideas?
  #25 (permalink)
Old 03-17-2010, 10:30 AM
Banned
as already stated its probably your exhaust system. Its the most likely culprit based on what you've stated. Start there.
  #26 (permalink)
Old 03-17-2010, 10:34 AM
Resonance is wierd knew a guy once with a mid 70s chevy truck and at a certain rpm you couldn't even hear yourself talk let alone anything else
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Would like a stronger sbc 350 than stock heads. StingRay69 Engine 6 11-12-2005 03:22 PM
350 SBC Build Help Mustangsaly Engine 25 06-14-2005 07:52 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
350 SBC...specific years? 78SilverShark Engine 2 10-14-2003 07:20 PM
