Sonoma/S-10 Door - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2003, 06:33 PM
bluesman123's Avatar
Post Sonoma/S-10 Door
I want to replace the drivers door on a 91 Sonoma, but when I looked the hinges seem to be spot welded to the body. Am I missing something? Is there a good way to take it off and put the new one on?
Thanks for your advice.
Old 02-08-2003, 07:29 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
You have to remove the hinge pins. There is a small retainer on each pin. After you get it off tap out the pins. You can get new ones with bushings and retainers at your local parts store for a little of nothing.
Chris
Old 02-09-2003, 03:28 PM
Post
Thanks TurboS10
Old 02-11-2003, 11:58 AM
tlambert's Avatar
Post
Don't forget about the spring in the hinge. You will need a small spring compressor to be able to remove the spring and to reinstall it. there is tool kit made for door hinge pin removal and installation.
Old 02-12-2003, 04:40 AM
TurboS10's Avatar
Wiki Edits: 2
Post
[quote]Originally posted by tlambert:
<strong>Don't forget about the spring in the hinge. You will need a small spring compressor to be able to remove the spring and to reinstall it. there is tool kit made for door hinge pin removal and installation. </strong><hr></blockquote>
I got by with a punch and hammer. As for the spring, well, it was a ******, and I wish I would have had the correct tool. Might have saved some small nicks in my freshly painted hinges.
Chris
