Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sorry another vacuum advance question
Old 01-17-2005, 04:35 PM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
I would check the inital timing as it is set now before hooking it up. If he set the initial real high, you could run into problems when the vacuum advance comes in.
You also have to choose where you hook it up, ported or full vacuum...there, I've said it and now we're going to get into a lengthy discourse on which port to use. I have my own school of thought, i.e use the one which runs the best.
