Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sorry another vacuum advance question
Old 01-18-2005, 05:29 AM
dmorris1200's Avatar
dmorris1200 dmorris1200 is offline
doesn't play well with others
The line to the tranny should be full manifold vacuum. You could simply cut the hose by the carb, add a T fitting, and try running your vacuum advance on manifold vacuum. You will need to readjust your carb. If you have a real hairy cam you may create some rough idle characteristics if the erratic manifold vacuum signal from a large valve overlap causes the vacuum advance diaphragm to constantly fluctuate the timing.
BUILT FORD TOUGH
