Sorry: Yet another 700r4 diagnostic question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2006, 07:26 PM
kawboykerry's Avatar
Greetings........I recently bought a 93 Caprice 9C1 and it has trans problems. It goes in to reverse fine and starts in low fine buy it does not shift.....ever. You can accelerate to redline(well as close to it as I dared)and won't shift. Then when you let off the accelerator it seems to go to neutral. The car had been sitting for a year or so. Just want some direction. If it has to come out, no sweat. Just wondering before yanking! Thanks for your input.
Kerry.........
1993 Chevy Caprice 9C1
Old 06-12-2006, 08:24 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
Is all of the linkages lined up right? I don't have a lot of tech experience but I'd check that and any wiring related to the transmission... also fluid level, pressures, etc... make sure it's something minor first.
Old 06-12-2006, 08:54 PM
airworld2's Avatar
yank it, rebuild it
airworld2
Old 06-13-2006, 10:51 PM
Thank you........thank you very much.
Old 06-14-2006, 06:37 AM
tnsmith10's Avatar
when will it rain???
Kerry.........
no shift on a 700r4 means govenor... but it is in a year range to where it might be an early 4l60e... does it have a cable that goes up to the throttle body from the passenger side of the trans??? if so, then its a 700r4, and id check the govenor... if it has an electrical plugin on the passenger side of the trans, its a 4l60e... if that be the case, drop the pan and inspect for debris... if none, it may be as simple as pulling the valvebody, and freeing up some valves (no govenor), or replacing the shift solenoids.
now, if ur not real familiar with transmissions, id take it to a trans shop and have them do a full diagnostic.
Old 06-14-2006, 08:19 AM
Yeah, it has a cable. Also the RPO sticker designates a 700R4.
another 700R4 tranny question ?? cares Transmission - Rearend 6 06-16-2006 01:26 PM
700R4 Question Not A T 25 Transmission - Rearend 5 06-12-2006 11:16 AM
New Guy and a 700r4 question John Fabris Introduce Yourself 5 05-10-2006 09:20 AM
1984 700R4 B&M Shift kit question Russell52 Transmission - Rearend 4 02-25-2004 09:45 PM
87 Camaro 700R4 Question Dans83Olds Engine 6 05-07-2003 09:39 AM
