Sorting out The wiring on my 37 Dodge? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2004, 07:38 PM
Tazz
I fried an in-line fuse and burned the + connector off the lug? All I did was connect the negative battery terminal to the battery after connecting the positive terminal then SMOKE! Something on the hot + side is grounded big time? This should be FUN/NOT! I'm glad I have a long weekend to figure this out. I HATE ELECTRICAL problems!!
Tazz
RAT Rods Rule!
Old 04-08-2004, 08:54 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
is it stock or modified??? cause a stocker would be a positive ground.....joe
Old 04-10-2004, 06:54 AM
Tazz
here is a site that shows my Dodge
http://www.geocities.com/bsm7095 go to" just for fun"
Definitely not stock. This is a 37 Dodge business coupe with a Mustang II front suspension and GM posi rear end with a 69 chevelle 327 and power-glide trans.
The car has an 85 Buick elect system grafted in. I am chasing grounds and looking for a short but nothing has helped yet, when I think I have found the problem and powered up the system I fry another wire?? I bought an ignition switch and am planning to install the painless wiring harness I bought to solve my problem. I had thought I would chase down the problem but am ready to replace the wiring system to get away from the head aches!
Tazz
Rat Rods Rule!
