Sound Deadener - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-15-2002, 09:46 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Pontiacman, Foam Seal is a two componant PUF system, its sold for marine and aotomotive uses it came out about 6-7 years ago when the europeein' racing (hondas and such) became popular in the USA. Its great stuff you should check it out and let me know. I've used the foam you use, I live in a moderate sized monolithic dome that me and a few friends built, we had to shoot that stuff up before the shotcrete.
  #17 (permalink)
Old 04-16-2002, 05:32 PM
Post
Hello Holloweenking, I've done monolithic domes before my foam has been around for 20 years, Resin
Tech manufactures it I've been spraying 12 years
over 25000.00 to get equipment here. Its a good sound deadener but better insulation material my product is r-7 per inch thickness, I've done vans
campers, artists also use for bronzes(life size)
It does completely set, 3-inches on sheet rock, 2 ft centers I can walk any where without falling through,don't have to walk on trusses. I'm almost 200 lbs.I have also done boats, cold here in Montana, really keeps heat in,
sound deading is just a extra quality it creates.
  #18 (permalink)
Old 04-22-2002, 07:00 AM
Wiki Edits: 49
Thumbs up
Street Rodder had a story a couple months back about a spray on insulation specifically made or cars. It's called Cool Car Ceramic and is only currently available from RB's. The link below well provide the specifics.
<a href="http://www.rbsobsolete.com/NewProducts/CCC.html" target="_blank">http://www.rbsobsolete.com/NewProducts/CCC.html</a>
[ April 22, 2002: Message edited by: Centerline ]</p>
  #19 (permalink)
Old 09-11-2002, 11:57 PM
Post
Have you checked out jcwhitney.com or their mags, they sell Heat Shield Insulation that you can buy in bulk rolls they sell 4-ftx24-ft for $65 and a 4-ftx48-ft for $120. JC Whitney has almost everything you would want for that job or resto. Good luck, hope you find what you want at your own affordable rate
  #20 (permalink)
Old 09-18-2002, 03:03 PM
Maverick's Avatar
Post
I plan to use Peel and Seal. Its sorta like what your talking about, its a roofing material that has a shinny alum. then tarie rubber type of material with a peal off back. Turns the echoing "BOOONG" to a quiet "thud". Its pretty thin and cheap. Great for lining doors, fire walls, roofs. I have heard you can get it at Lowes or Home Depot. I have been getting it from a roofing supply company. Later! My two cents!
www.mfmbp.com/peelseal
:p
  #21 (permalink)
Old 09-18-2002, 11:23 PM
New Member
Thumbs up
Go with the Peel & Seal !! I just used it in my 51 Chevy Pickup, It works great!!!
I got it at a local roofing supplier.
  #22 (permalink)
Old 09-25-2002, 09:23 AM
Mav's Avatar
Mav Mav is offline
Post
There are two types of foam , First , the kind you buy at home depot, It must react with moisture or air in order to cure
Second is two part foam. It chemically reacts and cures...
The best ive ever used is called handi foam
Heres a link www.fomo.com
Click the "Handi Foam" icon, then "Handy foam two part compound"
[ September 25, 2002: Message edited by: Mav ]</p>
  #23 (permalink)
Old 12-12-2002, 08:02 PM
Post
Yeah, you can get that Ice and Snow stuff at Home Depot. I've heard it does a good job and relatively cheap, well when compared to Dynamat. It's also suppposed to stick like crazy. Like once you let it set up, that's it, there's no getting it off. I went to Home Deopt and checked some out the other day. I found some stuff made my GAF called Weatherguard I was going to buy some until I smelled it. Man, this stuff reaks, I mean REAKS like tar. So here's my question. Has anyone used this in their car? and if so, does the smell go away. Cause the last thing you want is to spend a month scraping this crap off your floor pan cause you can't stand the smell.
Thanks to all who reply!
MJ
