Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sound Deadener
Thread: Sound Deadener
Old 04-07-2002, 11:37 PM
Halloweenking's Avatar
Halloweenking Halloweenking is offline
Fantastically cannibalistic!
Polyeurethane foam is very good for heat/sound, you can spray this stuff on and not only is it pretty cheap and great for sound and heat it will also help keep small dings from forming because of its strenth, you can get this stuff as strong as 20psi. Its also great if you have a unibody car and want to strengthen, just peel up the carpet move your wires and shoot it in the rails. Just make sure you cover everything you don't want it on, because this stuff will stick to anything and its not a peach to try to clean. If you plan to go this way let me know I'll find the company name and number I used for you.
