Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sound Deadener
Thread: Sound Deadener
Old 04-09-2002, 11:48 PM
Halloweenking's Avatar
Halloweenking Halloweenking is offline
Fantastically cannibalistic!
Thanks Paco, forgot that little bit of information, Polyurethane foam usually exspands 10x's its size, thats why its so good for the unibody cars because it will fill up those body rails and give your car a stiffer more responsive feel, its great for drag cars or an everyday driver if you want to go that far, but DO NOT use foam you by from the hardware store for this type of instalation, because the foam you by at the hardware store isn't for enclosed areas, if you use this type of foam it will become gummi and sticky and it will never harden and turn into a nasty mess, if your thinking about the enclosed instalation use foam from a company called Foam Seal, they have the best foam for this type of instalation, if you need contact information on this company let me know.
[ April 10, 2002: Message edited by: Halloweenking ]</p>
