Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sound Deadener
Thread: Sound Deadener
Old 04-12-2002, 10:34 PM
Halloweenking's Avatar
Halloweenking Halloweenking is offline
Fantastically cannibalistic!
True, working with PUF (polyurethane foam) does require ideal conditions, but if you seal your prodject correctly before the ffoam you should have no problems, I use all PPG products, sealers, primers, and paints. I use PPG because its a good product its easy to use and its fairly economical, and I also have a whole store room full, mixing equipment included straight from PPG. I'd use it even if I didn't though.
