Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sound Deadener
Thread: Sound Deadener
Old 04-15-2002, 08:26 PM
Pontiacman Pontiacman is offline
Before doing anything dry your project, don't want to seal moisture in .The SRRAY foam I work with you don't buy in a store, it takes a porportioning machine, heaters, transfer pumps,and a 1200.00 spray gun. My material is set in about 1-minute, the time it takes to cool from 120 degrees when sprayed up to 360 degrees when it raises then down in temp. my material is completly set and never changes in these qualities after incapsulated.My product is a 2-componet system, store product is single component.This is my business spray foam. I wouldn't advise any other foam other then sprayed in place,2-component foam. foil. ice dam material to hold down, heavy pad, carpet,completly dry first!
