Sound Deadener Insulation - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2010, 03:37 PM
Looking for info on rolls of sound deadener types. I found three types of sound deadener; one is foil on each side with a layer of fiber insulation total thickness 1/4"; another is same as previous except air bubble center, and last is one side foil backed with fiber insulation total thickness 3/8".
Which type is better for sound deadening and thermal barrier? Which type do you guys prefer? Is one type easier to work with than the other? To apply do you glue it down? In the case of single foil side which side faces up; the foil?
I am planning on installing it under the carpet all the way back to where the rear seat back meets the trunk. Does this sound right? Should I install it on the passenger side door surface and run it back into the rear passenger comparment? It's going on a 2dr LeMans.
Thanks,
BT
Old 03-28-2010, 06:16 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Take a look at this thread: CLICK HERE
And this thread: CLICK HERE
If you use the search function and type in "sound deadeners" you will find a lot more information.
Old 04-09-2010, 11:08 PM
Sir-x-Loin's Avatar
The kid is the man.
Search google. This subject has tons of info. The car audio sites have oodles of in depth info.
I perfonally use a Butyl and foil mat with 1/2" Jute over it. I have been looking into 1/4" closed cell foam mats to further reduce heat and noise.
Good luck
Sound clips of gear drives? Vids of cars w/ gear drives? Magnum Rockwilder Engine 12 08-14-2005 06:14 PM
funny engine sound brad11957 Engine 5 05-13-2004 09:59 PM
Exhaust Resonators (indy car sound) brainsboy Engine 18 03-29-2004 09:47 AM
Sound Insulation Questions F-1Rodder Interior 11 03-16-2003 05:15 AM
Sound Deadener Stinkin_V8 Interior 22 12-12-2002 07:02 PM
