Source for bandsaw blades? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2012, 06:23 PM
hduff's Avatar
Fix it until it breaks
Last journal entry: Matt got a new motorcycle.
I need to obtain a replacement metal-cutting blade for a 14" Wilton vertical bandsaw. The size I need is 3/8" x 92-1/2". The usual places like Harbor Freight, Northern, Sears? Or are there better (mail-order) souces?
Old 11-19-2012, 07:26 PM
406 bug's Avatar
9.82 @ 139mph
Try Grainger
Old 11-19-2012, 07:35 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
McMaster Carr
Sam
Old 11-19-2012, 07:41 PM
hduff's Avatar
Thanks guys. Had not thought of them.
Old 11-19-2012, 07:45 PM
Grainger or Dewitt tool for me
Old 11-19-2012, 11:57 PM
Banned
Welcome to Drills and Cutters | Drillsandcutters.com
Old 11-20-2012, 10:20 AM
Wiki Edits: 27
make your own
one of my saws has an odd size blade so I make my own, I grind a bevel about 6 times longer than the blade thickness, then clamp them in a jig and silver solder them together, then off to the belt sander to sand the weld area and check thickness with a micrometer so it doesn't have a lump weld.
Old 02-13-2013, 08:05 AM
There are sites that are do order to weld band saw blades.
Old 02-13-2013, 10:44 AM
kso's Avatar
kso kso is offline
A while back, with a small shop, I had a lot of trouble getting right-size blades, and then often times the welds would snap. Got so aggravated I bought a blade welder for $900 and started just buying in coils...pricey but then you always have some. Guys would walk in and buy blades from me sometimes, I think I charged ten bucks plus blade material.
Any old metal shop that has an upright "Do-All" band saw will likely have a blade welder as part of the saw.
But, you can weld your own with gas or tig. The trick is to hold the ends aligned well, and anneal it afterward, just barely have about a half-inch section of it glowing a little, not red hot, then bring the heat down slowly. When it cools, bend it a couple times to test then grind off the extra weld. It's actually as reliable as the blade welder, just takes longer. Maybe you want to grind the teeth back a little in that area so that part is not having to cut.
Obviously the way for a guy just wanting one blade is a good supplier of pre-welded blades, I'm just throwing in some comments.
Old 02-13-2013, 03:33 PM
Try checking this : BandSaw Blades Online - Custom Welded Band Saw Blades . My dad purchased blade with them last week.
Old 02-13-2013, 05:47 PM
Old Fool's Avatar
Super Cut blades in Rathdrum Idaho make some of the best band saw blades out there. The number of choices they will throw at you will make your head swim. Their prices are very fair too. Give them a call.
http://www.supercutbandsaw.com/
Old 02-13-2013, 05:58 PM
Who every you buy from , buy a quality blade. I had continuous trouble with a horizontal band saw until I spent a fair amount of money on a quality blade. All the difference in the world.
BB
Old 02-13-2013, 06:41 PM
See if there's a local Do-All representative in your area. I was very fortunate to have one as a friend, and I ordered my bandsaw blades from him, for my Buffalo horizontal bandsaw (46 1/2" blades). They were excellent quality. This was quite a few years ago, but I'm sure there are still reps out there that would be glad to help you out.
Old 03-25-2013, 06:34 AM
You can find one from ebay or silmilar sites.
I know its to check their reliability.
But here is a reliable source I trust as best metal cutting tools provider.
www.bipico.com
Old 03-25-2013, 08:02 AM
I've had good luck with Lenox bandsaw blades. I get them at my local Fastenal.
best reciprocating saw blades? matt167 Garage - Tools 38 01-12-2017 11:33 AM
Converting a ported vacuum source to a manifold source Scrumgees Engine 2 08-17-2011 01:09 AM
Bandsaw Mills C-10 Off-Topic 3 09-28-2008 10:51 AM
wiper blades? MARK TINNELLY Body - Exterior 11 01-30-2006 07:58 AM
Wiper Blades RCastle General Rodding Tech 9 02-01-2005 03:09 PM
