source for mopar flat head 6 performance parts
Does anyone have a good source for mopar flathead 6 performance parts?
First if you have any plans to keep the flathead let me say you can have a very reliable, decent performing engine that you will not see a 100 of at the next car show. The flatty will draw attention when you have the hood open. You will not win many drag races with the flatty, but I am very happy with mine. I had a 383 / 727 in my last 48 Plymouth coupe which ran like a scalded cat. I now have a 230 flathead and while it obviously does not run like the V8, I am pleased with what I have as I am a different kind of car guy than I was 30 years ago.
If you want a little more Umph out of your flathead try to find a 230 out of 50's Plymouth or Dodge. I recently made the change which was a bolt in and the performance difference is definately noticible. Drove the 218 as my daily for 4 years in Dallas and it did just fine but the 230 was an improvement. You need to check out the P15-D24 Site Once there you will find a ton of info on the Mopar flatheads. Also search for "Olddaddy" he sells a pretty much bolt on disc brake kit for the old Mopars as well as a front shock relocation kit. The old Plymouth has a good front suspension once the shocks are relocated. For Speed Parts You can look at Edgy Speed Shop for finned aluminum head, intake and reground cams Langdon's Stovebolt Eng Co for intake, cast iron headers and HEI distributor Transmission Another thing you will want to look for is an Overdrive Transmission. There are several options a stock Borg Warner R10 OD from a mid to late Plymouth or Dodge, a T5 from an S10 or some of the later Mopar 5 speeds. Paul Curtis for an adaptor to mount a T5 5 speed behind the flathead Quality Engineered Components for the late model Mopar 5 speeds or automatic behind the flathead. The R10 is a bolt in if you have the standard 3 speed now. All you would have to do is add a couple wires to control the Solenoid / Govenor. Alternatives for the OD transmission is a rearend swap to an 8 3/4 from a late 60's - early 70's Mopar B Body or a 89-90 Dakota rear with something like a 3.55 gear. Your stock rear is either a 3.90 or a 4.10 so the taller gear will help on the highway. Once you relocate the spring perches this is pretty much a bolt in. For Standard Rebuild Parts Terrill Machine 254-893-2610 (TX) Vintage Power Wagons Egge Machine Roberts Motor Parts Andy Bernbaum Some Other Interesting Reading Blueskies 50 Plymouth Build Interesting HAMB (Oh what a dirty word) Threads Hot rodded Mopar flathead 6's here? Flat head 6's lets see them 218 Performance bolt ons? Projects - Rebuilding the Plymouth Flathead 6 Here are a couple pictures of my 57 Plymouth 230 in my 48 Plymouth Coupe. On my Dallas to Joplin round trip for the HAMB Drags I got 20.9mpg out of it with the R10 O/D transmission running 65-70 MPH on the highway. http://tornadowarning.smugmug.com/Ot.../1003353-S.jpg http://tornadowarning.smugmug.com/Ot.../1003349-S.jpg I do not have any video of the 230 running yet but I do my old 218 and I think it sound pretty good. 218 Running |
wow! this has got to be one of the most detailed responses to a post ive ever seen what a ton of information!great job :thumbup:
Thanks helrazr3, I have always been a Mopar guy and over the past 4-5 years have gained a bit of knowledge / info on the flatheads. They are really a pretty good power source and Mopar produced them virtually uchanged up through the early 70's for use in industrial applications, so parts are readily available at NAPA, Autozone, Tractor supply/repair facilities. They were used a lot in fork trucks, airport tugs, irrigation pumps, combines, tractors etc.
Need to make one revision to the info I provided after reading through it again. On my post above the reference to the Borg Warner R10 OD should say from a mid to late 50's Plymouth or Dodge. |
Great engines... so many got tossed out with the trash over the years.
great info, too BTW. |
The bore of the 218 and 230 are the same. |
Great info, excellent engines, beautiful pics!
I'm working on a 49 Coronet with a 230 in it. This has been the most information I've been able to find on parts anywhere. Thanks for posting this.
| All times are GMT -6. The time now is 02:16 PM. |
