Source for new/rebuilt HEI Distributor Mainshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2005, 10:10 PM
acr acr is offline
Besides from GM, does anyone know where I can buy one of these for a SB Chevy?
Thanks. acr
Old 06-26-2005, 09:20 PM
docvette's Avatar
Wiki Edits: 12
Main shaft
Doc here
Did a brief search, Nobody seems to carry that part and what may be for good reason...It never wears out!
You may need to replace the Shaft housing bushings (which are available at GP Sorensen) And that Should cure any slop issues...Unless it was run well out of run-out with no or dirty oil after the bushings wore away, It should be re~Bush-able..
The only other advice I could offer is write (email ) GP Sorensen Direct or the Bone yard with a Micrometer and a bunch of time to spend..
In either case, I should think you'd be investing more time and money than GM direct, or an aftermarket replacement..unless Resto accuracy is tantamount.
Doc
What is George Bush's Real IQ? NAIRB Off-Topic 98 09-03-2006 02:04 PM
early optispark vacuum source 48Man Engine 7 01-16-2003 01:17 PM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 02:38 PM
Big Block HEI problems!!! woodman13 Engine 4 12-20-2002 08:39 PM
Power to HEI Seon Electrical 3 09-27-2002 03:03 PM
