Southern or northern exposure for metal building - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2011, 03:25 PM
Last journal entry: Suggestions worth sharing
I'm looking at erecting a workshop/garage using a post frame building covered with metal siding and R-5 insulation board. It will be attached to an existing building which is 4 feet taller, attached on the gable end. I have a choice of putting it on either the north side (with garage door on the east side) or the south side (with the garage door on the south side) of my existing building. If I put it on the south side, when I open the door in the summer I will get prevailing southwest winds for ventilation. However, it has also been pointed out to me that the summer sun will also heat the building more on the south side, while that end would be shaded by the existing building if I put it on the north side.
So, I'm not sure which factor weighs more heavily, the extra breeze in the summer or the shade from the existing building. Any suggestions?
Old 06-04-2011, 05:20 PM
I see you are in KC. I would go on the South. In the hottest months of summer, the sun will actually beat down more on the North side than the South side. The prevailing wind is from the South will tend to cool the building more at night and you will start the day with a cooler building. And the breeze (when it is not wind) will be more comforting. But the South sun in the winter, plus the sheltering building will block out those strong, cold North winds you get in the winter and that is a big plus.
Trees
Old 06-04-2011, 06:39 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Trees has a good point and if you can get ventilation up high that will help in the summer..
Sam
Old 06-05-2011, 12:44 PM
Thank you both for your helpful comments.
Old 06-05-2011, 04:30 PM
I'm sorry, when did the Earth's axis move? I must have missed it.
In the northern hemisphere, the sun will ALWAYS be stronger on the south side of the building. The bigger consideration should be the cold wind of a northern exposure in winter. Put it on the south side.
Hello from Northern MD mkhurley Introduce Yourself 2 12-09-2008 08:56 AM
rusty metal primer on clean metal, pine trees and brawling Stroke Body - Exterior 3 06-01-2008 07:29 PM
Steam Show Pics- Northern Southern MI ChevelleSS_LS6 Hotrodders' Lounge 10 10-05-2007 12:44 PM
HELP! very stange metal on metal upper bushings on a chevelle, is this factory? younguyw/oldcrap Suspension - Brakes - Steering 3 05-30-2004 05:17 AM
Anybody ever put up their own metal building garage?? Fireball Hotrodders' Lounge 9 05-31-2003 10:55 AM
