spacer for a 650cfm carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2011, 02:40 PM
I have a 327 bored .030 over with 650cfm edlebrock carb and performer intake and a mild rv cam. It runs great, but when I romp on it, it gets a little sluggage. The kick down switch is working fine. Do I need a 1 inch spacer under the carb to get more hp? I have nothing now. thanks for the feed back
Old 11-17-2011, 03:12 PM
techinspector1's Avatar
Wiki Edits: 326
More detail please. What's the fuel pressure when you romp it?
Old 11-17-2011, 03:21 PM
Im sorry I don't have a gauge hooked up to it. I can put one on. It feels like i have to give it to much throttle for it move. Its in a 69 chevy impala. does that help?
Old 11-17-2011, 03:35 PM
Wiki Edits: 326
No.
Are you talking about from a stop or while cruising and gettin' on it? Is this problem new or has it been doing this for a while? Do you smell gas? Have you pulled the spark plugs to inspect them for color?
Old 11-17-2011, 04:16 PM
from the take off. It won't build power till about 3000rpm. the enging has 1000 miles on it. it's fairly rebuilt. everything is new in it. the spark plugs are on the whiteish color. Its been doing that since i put it in 1000 miles ago. I smell gas only on air filter. I sent a picture of my enging.
Old 11-18-2011, 11:22 AM
Wiki Edits: 326
Well, that's at least part of the problem, the motor is lean.
It is imperative that you learn how to tune the carburetor. That's where all those undeserved names come from, is fellows who have no idea how to tune a carb and then call it names because it won't do what they want it to. Names like Edelbroke and Quadrajunk were started by those who lack the intelligence to tune the units "by the numbers", so it's easier to call them names. The Edelbrock design was taken from the old Carter AFB design, a carburetor that has enjoyed long success and used to be installed as original equipment on many makes of new cars and trucks. You can dial it in as close as a gnat's eyebrow if you just pay attention to the basics.....
http://www.edelbrock.com/automotive_...ers_manual.pdf
If there is some reason that you cannot absolutely and completely understand this tuning information provided by Edelbrock, then email or telephone the techs at Edelbrock and have them explain it to you. Again, it is imperative that you learn how to tune this unit. Now get busy.
http://www.edelbrock.com/automotive_.../contact.shtml
Also, pay particular attention to the recommended fuel pressure. Tee off at the carb inlet and run a line up to the cowl and mount a temporary mechanical fuel pressure gauge (with tie wraps or duct tape or whatever, it's only temporary until you get the pressure nailed down) on the cowl of the car in front of the windshield so that you can monitor fuel pressure while you drive. Too little pressure is as bad as too much pressure. Use a liquid-filled, 0-15 psi unit, mechanical.
Old 11-18-2011, 11:20 PM
thank you so much I will do that tommow. any suggestion on what spacer i should get?
Old 11-19-2011, 12:02 AM
The only thing I can tell you as of now is to see if a Carb spacer
will fit on your intake. Some Carb/intake setups wont allow a
One inch spacer without wasting a bunch of useless time and money.
The 4 hole Carb gasket is for stock intakes, since you have an aftermarket
chrome intake you want one that's open. Thicker is usually better.
the rest is up to you or someone else I guess. Good luck
Old 11-19-2011, 01:17 PM
Wiki Edits: 326
Forget the spacer for now. They're for fine tuning a combination and you never know what will work best, so you have to try several different combinations of closed, open and various thicknesses. Get the tune correct on the carb before you worry about anything else.
Old 11-19-2011, 04:47 PM
ok thank you very much
Old 11-19-2011, 11:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I would suggest you be sure the timing curve is acceptable before tuning the carb any differently that how it came out of the box. So I would recommend you baseline the carb back to its original specs, then proceed to set up the timing curve. After the timing is dialed in you can proceed to fine tune the carb.
Supply any/all of the following info and we can take care of the timing and lend some assistance w/the carb tuning:
type of distributor- did you convert from points to an HEI? If so did you wire it correctly? The HEI needs to be wired w/o using the original resistor wire that the old points ignition used.
type/size of engine. You've said it's a 327 SBC.
camshaft specs (duration, LSA especially) or at least the make/part number. Just saying "mild RV" doesn't really tell the whole story. If that's all you know or can find out about it, the vacuum at idle as well as the idle "quality" (i.e. does it 'lope' or is it smooth) will help determine how radical it is.
intake type (single or dual plane). I see you have a dual plane and the carb is a 650 Eddy.
the timing (initial, total, "all in by" RPM, vacuum advance or no, how much vac. adv. supplies, hooked to manifold or ported vacuum)
the CR. Do you know if the pistons are flat top, or ? What is the casting number of the heads?
engine vacuum at idle
current carb specs (jet size, step up spring color, rod size, accelerator pump linkage hole setting, turns on the idle mixture screws, any changes that have been made from how the carb was set up originally)
Along w/the vehicle specifics like:
weight. Going to say you prolly weigh at least 3800 lbs.
rear gear ratio
trans type. You mention having a "kick down switch". If that's correct, you have a TH400. Is that correct?
converter stall speed
the way you use the vehicle (race, w/e toy, parade, DD, etc.)
Then describe:
the symptoms of what the vehicle is (or is not) doing that it should be doing. You mention sluggish take off. Is this all that's wrong? Does it stumble or pop through the carb? Or is it smooth, just slow feeling?
what RPM the problem occurs, if other than just off idle.
There are several different damper/timing tab combos that have been used through the years. If they are mixed up the timing can be different than what you see w/a timing light. DETERMINING TDC will allow you to be sure the timing tab and damper are correctly indicating TDC.
MAKE A TIMING TAPE to see what the total timing is, w/o needing to use a dial back timing light. You can also buy a timing tape, get one that matches the diameter of your damper.
Best carb spacer style Edelbrock carb truckboy61 Engine 2 07-24-2011 10:18 AM
Will adding a 1 inch carb spacer affect carb tune? eric32 Engine 29 02-09-2010 01:13 AM
Carb install, spacer or no spacer? MM in NM Engine 3 03-17-2006 07:23 PM
Carb spacer 72elcamino Engine 6 11-12-2004 10:30 PM
Is a 650cfm carb noticeably better than a 600cfm Stinky Engine 1 06-18-2003 10:00 PM
