Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Spare tire on staggered tire setup..Front or Rear??
Old 05-19-2012, 05:31 PM
Blazin72's Avatar
Blazin72 Blazin72 is offline
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Ford sends certain Mustang models out from the factory with that "slime" stuff and 12v air compressor in lieu of a spare tire. I'm not a fan of that idea but that's the way they did it. Something about weight savings....
Anyway, if this were my car I would size the spare tire to match the rear tires because of the axle. I don't know how much an offset tire size would really affect an open differential but if you have a limited slip, locker or a spool then the spare absolutely should be the same size. The fronts are totally independent from each other so an offset tire size won't hurt anything as a spare, other than maybe an off center steering wheel.
