Spark Gap Recommendation - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2010, 06:26 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
I am running 0.045 gap on my vortec headed 383 with about 9.5 scr. I have a skip supplied HEI with supposed 65000 volt coil and moroso 8mm wires. i am running AC R44LTS plugs and have a base timing of 16 btdc, 221/230 duration cam @ 0.050, eddy 1405 carb, headers. A friend told me that 45 is too much. What would be correct for this application? What are some of the effects of having too much gap?
Old 05-30-2010, 07:57 PM
I run .055 on all my hei cars.
Old 05-30-2010, 08:03 PM
techinspector1's Avatar
Wiki Edits: 326
The higher the cylinder pressure, the more difficult it is to get the spark to jump across the gap, resulting in mis-fire. Also, the wider the gap, the more difficult. I have had no mis-fire problems with street/strip motors running at 0.045" to 0.050" with an HEI.
Old 05-30-2010, 09:09 PM
Custom10's Avatar
thanks fellas, i figured i was OK with 45
Old 05-30-2010, 09:19 PM
sickolds's Avatar
sickolds
45 is what i have on mine NGK plugs 383 vorteck heada
Old 05-30-2010, 09:22 PM
sickolds's Avatar
sickolds
y 16 on timing 12 is what i have on my 383 am i w rong
Old 05-30-2010, 10:26 PM
Custom10's Avatar
yes i have responded to your issue on the thread you started...go there and we can carry on.
Which Spark Plug Gap? rac43 Engine 5 02-02-2007 06:08 PM
Spark plug gap chirpn69 Engine 2 07-09-2006 09:43 PM
spark plug gap? Lightspeed Engine 4 10-28-2002 12:01 PM
spark plug gap sudo1a Engine 2 10-11-2002 05:11 PM
spark plug gap hogerdoger Engine 1 04-06-2002 07:46 AM
