Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Spark Knock Fix
Thread: Spark Knock Fix
Old 09-09-2008, 07:24 PM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
At 5300 rpm it sounds like you are right into it with the secondaries wide open, have you tried going up one jet size on the secondaries? I would do a plug chop at rpm to see what you are getting for mixture at high rpm.
Colder plugs likely won't solve the problem unless you are really lean at which point a jet change on the secondaries should solve that.
10.75 is pretty high for a street motor, not much you can do about the poor fuel quality either so you might want to consider putting in a thicker head gasket or running fuel treatment or a gallon of race gas at each fill up.
