Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Spark Knock Fix
Thread: Spark Knock Fix
Old 09-09-2008, 07:56 PM
automotive breath's Avatar
automotive breath automotive breath is offline
It the cam was shorter duration, the problem would be much worse. Your
plan is good, the engine needs the higher initial to run right at idle/low RPM,
but less total to eliminate the ping completely.
