spark only sometimes on an Hei - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2010, 08:55 PM
I have just installed an OEM TBI fuel injection on the 250ci inline 6 in my '57 Chevy Suburban. I have modified the distributor to be run by the ECM.
I have gas at the throttle body but not much sparks.
I have pulled 3 spark plugs (1 at a time) to check for spark, cranking the engine, and:
1 spark plug has spark often, normally, it seems;
another spark plug had spark some times, like 4/5 sparks then none for a few seconds then again a few...
yet another spark plug had only one spark over the 10-20 seconds I was cranking the engine!
With my limited electrical knowledge, this does not make sense at all!
Plugs, plug wires, cap, rotor are new; coil is not new but worked a few months ago, module is junkyard used
Can anyone help?
Thanks!
Old 09-11-2010, 02:29 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
For one thing, the HEI coil needs to receive full battery voltage. You cannot power it by using the resistor wire/ballast resistor that was used on the car originally, you need to run a wire to the HEI that does not have added resistance.
Old 09-11-2010, 12:37 PM
The truck had the HEI before the EFI mod and worked fine, electricity comes directly from the ignition switch.
Old 09-11-2010, 02:26 PM
LATECH's Avatar
What or how did you modify the distributor and what distributor did you use?
Also which efi system?, from what , ? And what is the ecm number and what is the prom number?
Also you should put a test light on the positive side of coil to check while cranking. Maybe you are losing power while it is cranking.That old school ignition switch might not be too good or capable of handling the power that is required by the hei.
Old 09-11-2010, 03:13 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
What year Chevy is the TBI from?
What mods were done the distributor?
Have you installed all the sensors and controllers that the ECM needs to operate?
Coolant sensor.
WOT switch.
Closed throttle switch.
Vehicle speed sensor.
Barometric pressure sensor.
Manifold absolute pressure sensor.
Idle speed control switch.
Distributor reference pulses.
Throttle position sensor.
Oxygen sensor.
ETC
vicrod
Old 09-11-2010, 03:45 PM
http://www.ifsja.org/forums/vb/showthread.php?t=69362
These are the main instructions I have used to modify the distributor; I did this without taking the distributor out, it was very easy.
http://www.binderplanet.com/forums/s...ad.php?t=47254
This is a site where I have found a lot of info, too.
The harness and ECM, as well as all sensors, come from an '88 Chevy half-ton. All the sensors are conected except the 02 sensor, because my exhaust is not done yet. I have read that the engine should run without the 02 sensors.
The distributor is a '78 Camaro, the engine is a '75 Camaro; it all worked fine before the mods. The ECM number ends in 747, I think, a very common one.
Old 09-11-2010, 05:47 PM
randolphi's Avatar
Ok or not ok---plugwires-maybe
I have run in to this problem, more than once, new wires, with the ends not installed (do it your self), and also pre-assembled but economy brands, that often disapointed me. The best test for the coil for me, after I make sure the connections are good, including (plugs back in).
I take the end of THE COIL LEAD TO distributer out of the distributer, but not all the way off of It-- just prop it up near the distributer center- about a quarter inch, and then watch and listen for spark, while cranking-- should sound continuous without any pauses, and be bright, and loud, also (BE PREPAIRED iF THE ENGINE STARTS.) YOU KNOW parking brakes, in neutral, no fumes from gasses, no tools near fanbelts, and OH yeah dont have someone hold the wire while you crank.
Old 09-11-2010, 06:01 PM
My HEI distributor is a coil-in-cap...
Old 09-11-2010, 08:57 PM
vicrod's Avatar
life is a ride
GM made a change in 1980 where the distributor was redesigned and known as an Electronic Spark Timing (EST) distributor which is part of the C4 or CCC systems.
The older distributor is likely not compatible with the 1988 TBI you have.
vicrod
Old 09-11-2010, 09:34 PM
LATECH's Avatar
I looked at the info you posted and if you did it like the instructions the only thing that comes to mind would be maybe you have the pickup coil hooked up backwards polarity.It doesnt say what color the positive or negative should be. The "P" wire and the "N" wire may be reversed but you should check polarity with a dvom. it will read the value generated and also the polarity will be displayed. does your harness have the little tan with black wire with connector for timing setting?adjust? if so maybe unplug it and check spark integrity then. I just dealt with an 88 pickup equipt with the 1227747 ecm and tbi and the timing was all over the place due to a POS ecm.
The pcm doesnt come into play untill it sees an engine rpm of about 400 rpm as the module has a bypass circuit for starting but it could be wacking the spark and timing if it is signaling the module to switch or sending mixed signals as the ecm sends a 5 volt signal to the module to switch it.unplugging the timing connector and rechecking will at least eliminate that as a possible culprit. I would check the polarity of the pickup first.
Old 09-11-2010, 09:36 PM
LATECH's Avatar
I would also have started with a newer model year distributor like an 83 or 84 with est.( as vicrod suggested). There were 2 designs and the one would have the external coil and you would not have had to alter the harness for the coil and the distributor.but i guess you run what ya got. good luck
Old 09-12-2010, 04:55 PM
I know about these different designs distributors, but with a 250ci inline6, the choice is limited! This is also why I have modified my distributor, to make it compatible to the EFI system, locking the weights and adding an electronic module, for instance. Yes, I run what I got and it would be easier if I were rich!
Old 09-28-2010, 06:08 PM
OK, so I appreciate all the help from you guys, but I am still stuck. I have gone over the distributor wiring to make sure it is good; tried to unplug the timing connector; checked the polarity of the pick up coil (and even switched the wires to make sure), but still nothing! I have tried 2 ECMs, 2 ignition modules.
I have heard that the ignition and the injectors are "connected" and that one will not work if the other does not: I always had gas at the throttle body (wet butterflies, gas smell), so... Although last night, there was no sign of gas...
The O2 sensor is not connected because the exhaust line is not built yet, but nowhere have I heard or read that it was needed.
I guess I need to go over the whole harness, how do I do that? Is it just a matter of checking continuity for each single wire? Is it possible to check that the connectors to the ECM are good?
Any other ideas?
Thanks!
Old 09-28-2010, 06:36 PM
LATECH's Avatar
did you use the ignition module from the 88 pickup truck when you converted the distributor from the camaro?
Old 09-28-2010, 07:40 PM
Yes, harness, ECM, module, connectors, throttle body all come from the same donor truck, '88 Chevy truck.
350 TBI spark problem driving med crazy!! Erst Engine 13 09-27-2016 04:39 PM
Chevy HEI - Weak Spark daveturnbull Electrical 5 07-25-2011 09:58 AM
318 ignition spark mystery(help!) androopa Electrical 8 10-30-2008 11:07 PM
HEI: No Spark Goobzilla Electrical 17 04-17-2003 12:27 AM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 02:38 PM
