Hotrodders Bulletin Board
#1
Spark plug
i have a 1994 Bravada with the 4.3 W Vortec. how hard is to remove the #3
plug? i dont like using u-joints. i was thinking of buying the Cratsman 3?8 breaker bar, also the wires are hard to remove. |
#2
Plugs should not be that tight, that you need a breaker bar to remove them.......bet they are aluminum heads and the threads are seized. Anti-seize should have been used when they were installed.
#3
not to worry, they are still cast iron heads. you're right with the swivel(like it or not). #3 is blocked by the intermediate steering shaft. you can get to it with a swivel plug socket and a very long extension through the fendewell.
push up the rubber extesion on the inner fender and go in over the frame. really not that bad to do. hope this helps. |
#4
According to Weimer...the way to get to the plug is to remove the steering shaft, which is relatively easy and the correct way to do it. He said his neighbor fought for hours trying to get the plug out and Weimer went over, removed the shaft and had it done in a matter of minutes.
#6
The wires probably didnt see any die-electric grease on them... i have one of these http://www.sears.com/sr/javasr/prod...pid=00947068000 that works good to help remove stuck wires, hope that helps.
#7
you got the post link? |
#8
I'm not a huge fan of using u-joints either, but I found a spark plug socket that has u-joint built right into the drive of it. It was around $7 at the local Fleet Farm. Seldom do I change plugs now without it. Also, the extra inch or so for the joint in it gives that bit of extra clearance to get past the heat shields.
Oldschool, that's the same tool I own. You didn't raid my toolbox to "borrow it", did you? J/K! Good money spent on a very usable tool. In a while, Chet.
It's not what you take with you when you leave, it's what you leave behind you when you go. My Monte Carlo Addicts site |
#9
No swivel sockets? How can anyone work on a vehicle without them, i consider them the most inmportant set of sockets i own, especially on engine work and transmission's. Alot of times people cause more damage and strip the head off because they try to get a regular socket.
How do you guys not use swivel sockets? Brendan |
Back to top |
Similar Threads for: "Spark plug"
| Ignition system info................ | poncho62 | Electrical | 18 | 10-11-2008 10:10 PM |
| Spark Plug brands question | Francis | Engine | 65 | 07-15-2008 12:01 AM |
| recomended spark plug.. | screamin340 | Hotrodding Basics | 2 | 11-18-2005 07:17 AM |
| Spark arcing outside the plug?? | 85MonteSS | Electrical | 16 | 11-16-2004 10:02 PM |
| What heads for a 350 have the spark plug wires on top? | batman09 | Engine | 13 | 09-25-2004 10:52 AM |
