spark plug choice - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2013, 11:40 PM
spark plug choice
I have a 40 over 350sbc in my drag car with flat tops and phase two bowtie heads with 64cc chambers.this heads had 184 runners i believe but have been professional port out to about 194 and have 2.02 valves.I've been running auto light racing 134 spark plugs but have to replace them often and been told need a hotter plug by guys at track.wondering if anyone had a recommendation on what would be a good plug to use.i run a 750 holley and i putting quite a bit of fuel to the motor.any advice would be gratefully appreciated .
Old 05-22-2013, 03:22 PM
The carb is borrowed so unsure of the jets probably factory its a holley 750 vacuum secondary.the cam us a comp extreme energy. 12-677-4 advertised duration 274/280 with .501/510 lift and i have 1.6 roller rockers.i know carb had a kit in it last fall.my main concern is i have been told the ar134 plugs are not a hot enough plug for the compression i have now.on new plugs car runs good 8.15 in the 1/8 at 86mph but after 20 to 30 passes plugs are dead .wondering if a different plug would help this.i would like to stick with autolite if i could.
Old 05-22-2013, 03:29 PM
Are they fouling with fuel or oil, or busting up? The former would need a higher heat range to get'em and keep'em clean. It they are busting up it would mean detonation or preignition in which case a hotter plug would be the wrong direction to go.
Bogie
Old 05-22-2013, 03:52 PM
They are fouling.pulled them othet day and they were extremely wet with fuel.i believe they need to be hotter just don't no how much and what to use
Old 05-22-2013, 08:45 PM
Are the RV8C's a short plug or long.I'm used the ar134's because there short to work with my headers because the bowtie heads are angle plugged so the don't leave much room with my headers .
Old 05-23-2013, 12:11 PM
The AR134 is only one heat range below the hottest range for that plug. A heat range typically changes the tip temp about 100 degress F. So if these are soaking wet, I'd be inclined to look at the mixture ratio more-so than the plug heat range at this point.
Bogie
89 5.0 H.O. spark plug wireing/spark order psikpa Modern Electronic Engines 6 05-11-2012 08:01 PM
How does this spark plug look? kyle86 Engine 21 07-26-2010 09:54 AM
Spark plug wires jumping spark STATUTORY GRAPE Engine 4 10-04-2009 05:14 AM
Spark plug choice for vortec heads? SBCfan04 Engine 15 10-02-2008 08:42 AM
Which Spark Plug #? joe brienza Engine 2 04-18-2006 08:52 PM
