Which Spark Plug Gap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2007, 04:48 PM
rac43's Avatar
I have a 355 SBC with HEI ignition and just got a new set of Edelbrock RPM heads and the RC-12YC plugs Edelbrock recommends. Should I use .035 or .045 gap with this HEI system. Please advise as I have been told to use both gaps at different times. Thanks
Old 02-02-2007, 05:08 PM
nitro_baller4692's Avatar
floppers forever
have you gone to www.sparkplugs.com
read sparkplug 411
Old 02-02-2007, 05:58 PM
rac43's Avatar
read sparkplug 411
Thanks but I don't need to know how spark plugs work. Learned that 50 years ago..
Old 02-02-2007, 06:01 PM
the coil capacity rating determines practical max gap for a resonable coil life
as the gap increases, the coil has to build to a much higher voltage before it is able to arc across the gap
.035= you need a coil rated at 30kV, actual spark voltage is approx 10,000V
.045= you need a coil rated at 40kV, actual spark voltage is approx 15,000V
(those are really rough #'s to illustrate)
HEI is 45-50kV
Old 02-02-2007, 06:06 PM
Wiki Edits: 31
Spec for most HEI is .40-.45 for a stock 40KV coil
Old 02-02-2007, 06:08 PM
poncho62's Avatar
Wiki Edits: 5
.045
Ignition system info................ poncho62 Electrical 18 10-11-2008 11:10 PM
Cylinder pressure vs. spark plug gap 70bird Engine 3 05-28-2005 09:25 PM
spark plug gap on BBC ratlover Engine 1 06-06-2004 06:53 PM
Spark plug gap FASTMONTE Engine 5 05-21-2004 07:06 PM
Spark Plug Gap, Timing scottgto Electrical 3 06-20-2003 08:38 PM
