spark plug gap - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2013, 04:59 AM
spark plug gap
What is the best plug gap and timming for a mild built 1986 chevy 350 with a hei dist.
Old 09-12-2013, 05:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
0.035" to 0.040" plug gap is fine.
If you have a stock cam and compression ratio *as a starting point* you can use 10 degrees BTDC for initial timing, total timing (mechanical plus initial) of about 36 degrees, mechanical advance all in by no more than 3000 rpm, vacuum advance hooked to manifold vacuum supplying about 12-14 degrees additional advance under light throttle/high vacuum cruise conditions.
Now, this is a general guideline- you'll want to tailor the curve to work best w/the combo you have. The main thing is you want to add as much timing as you can, as soon as you can- but without causing pinging under load.
A page w/info on the GM HEI, including setting up the advance curve, vacuum advance, making a timing tape, etc. is here.
Old 09-16-2013, 05:10 AM
Thanks for the info, I'll see if I can dial this pig in
Old 09-16-2013, 06:19 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you have a carb, after a thorough warm-up, adjust the idle air mixture screws to give the most vacuum at idle or highest rpm. You may need to readjust the idle speed as you go. Keep the screws within 1/4 to no more than 1/2 turn from each other. If you're not sure where the adjustments are, lightly seat the screws while carefully counting the turns. Then back them both out equally, to the most turns out of the two, then adjust them from there.
spark plug gap 1964chevelle General Rodding Tech 1 02-07-2005 08:37 PM
Spark plug gap FASTMONTE Engine 6 05-20-2004 04:55 PM
Spark plug GAP rehjr0219 Engine 3 02-18-2003 09:57 AM
spark plug gap? Lightspeed Engine 4 10-28-2002 11:01 AM
spark plug gap sudo1a Engine 2 10-11-2002 04:11 PM
