Spark plug gap for Vortec heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2011, 07:57 PM
I have a 5.7 90 truck with vortec heads and I'm trying to gap my spark pluges. I bought some plugse and they didn't last long so I did some reading . Come to find out I was buy the wrong pluges. The vortec heads use a longer spark pulgue so now I need info on gaping them.
Old 01-01-2011, 09:29 PM
DoubleVision's Avatar
Most plugs that are factory replacements come pre gapped. I gap mine at .045.
Old 01-01-2011, 10:14 PM
What plugs are you use ? I'm thinking of going with the accel 516 or the R44lts ..thanks for the help
Old 01-02-2011, 05:23 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
You could also run these 41-932; R44 LTS; colder marine plug MR43LTS Ac delco
Old 01-02-2011, 07:43 AM
The truck is my DD , I put in 650 miles a week. The 5.7 is stock with a 1405 eddy carb. it had NGk and they didn't last 3 months , I pulled a plug and it had brown rust on the plug. They went from a .035 gap to a .040 gap.
Old 01-02-2011, 12:22 PM
Don`t run anything with accell written on it. pure junk. I stick with tried and true AC Delco`s, if I can`t get them I use bosch platnums.
Old 01-05-2011, 01:13 PM
FastOrange's Avatar
NGK TR55's (NGK makes the ACDelco plugs) gapped to .040 if using an HEI.
Old 01-05-2011, 03:13 PM
Pennsy86monteSSGuy's Avatar
Another Old Gear Head
I'm running the NGK plugs gapped at .045, runs great.
Spark plug choice for vortec heads? SBCfan04 Engine 15 10-02-2008 08:42 AM
Vortec heads Nitrous / Plug temp questions! NDNslicks4me Engine 5 06-07-2005 09:43 AM
Vortec heads plug temp question NXS Engine 9 04-01-2005 07:43 PM
What heads for a 350 have the spark plug wires on top? batman09 Engine 13 09-25-2004 10:52 AM
Which Spark Plug Suffix on 333882 Cylinder Heads? FBody Engine 3 09-08-2004 09:45 PM
