Spark plug help for SBC 406 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2012, 05:19 PM
Daubers's Avatar
Apprentice
I have been doing a lot of searching and have not been able to find much consistency in the results so I thought it best to just ask the experts for my particular application.
400 bored 30 over
lunati lightweight rotating assembly
235 265 lift cam
202 camel hump heads
victor jr intake
1:5 rockers on intake and 1:6 on exhaust
roller rockers
800 barry grant carb
all msd ignition
Engine has under 100 miles on it. Just got it in a nova I bought. Had autolite 353 plugs in it which i hear are more for marine and small engine applications. What plugs and gap do you guys recommend? Thanks in advance!
Old 09-20-2012, 09:38 PM
vinniekq2's Avatar
what heads,CR,and clarify camshaft? are you having issues?what ignition?
Old 09-20-2012, 11:25 PM
The heads you have on the 400 cid are early model (before 1970) 202 camel hump heads right? Well if your compression is 11.0 or higher you need a colder plug. The pre-70 heads use R44 with 11.0 or less compression. Use R42 if high compression of 11.0 or higher. On 1971 and later heads use R44T on 11.0 or less compression. Use R42T if 11.0 compression and higher. You can get these plugs cross referenced at your Auto Parts Store to Autolite plugs. Try to avoid using R44TS plugs. The S on the end stands for extended tip.
The Following User Says Thank You to cdminter59 For This Useful Post:
Daubers (09-21-2012)
Old 09-21-2012, 06:41 AM
Daubers's Avatar
Apprentice
Thanks for the responses guys. Sorry I should have noted they are the older heads with 13/16"gasket seat plugs, also running 10:1 compression. If it changes anything I am running a MSD 6AL Ignition. I was told its an MSD distributor, but I have not had it out or even the cap off yet to tell the model. If there is any other information that would help narrow down my starting point please just let me know!
Old 09-21-2012, 10:33 AM
Daubers's Avatar
Apprentice
any last recommendations before I head to Autozone? or should I just pick on from the list recommended?
Old 09-21-2012, 12:14 PM
Daubers's Avatar
Apprentice
Well that was a wasted lunch break. Autozone didn't have ANY of the plugs recommended! They attempted to cross reference and the only plug they came up with was the autolite 353 ( which is what is in it now that i was told weren't good). Guess i am stuck ordering them
Old 09-21-2012, 01:03 PM
1971BB427's Avatar
If you read your MSD instructions you'll notice they say to open the gap up wider than the stock .035" gap. It says to adjust them between .044" to .060" with the MSD. I run mine at .045", and that seems to really work best for my setup. I'm running Champion RJ12YC in my 327 with the old 2.02 heads, and a Isky 270 cam.
Old 09-21-2012, 01:57 PM
Spark plug help
Check out this website it list all the plugs cross referenced to an AC R44. Alternative spark plugs for AC DELCO R44 If your plugs are on the list use them. I have the MSD 6AL Box with a MSD Pro Billet Distributor. I gap my plugs at .040. The bigger the gap the longer the spark has to travel.
Old 09-21-2012, 02:06 PM
Daubers's Avatar
Apprentice
awesome thanks!!!
Old 09-21-2012, 04:02 PM
Daubers's Avatar
Apprentice
Thanks for the great detailed response and explanation on gap. Helped me understand alot better. Just picked up some Autolite 303's. Will, put in tomorrow, rejet my carb as nd hope to nail the timing down
Old 09-21-2012, 06:37 PM
Spark plug help
400 bored 30 over
235 265 lift cam
victor jr intake
roller rockers
all msd ignition
Can you restate your lift and duration of your camshaft. Those figures you have don't seem right.
Old 09-21-2012, 07:17 PM
Daubers's Avatar
Apprentice
Sorry typo. Duration is 285/295 lift is .507/.534
Old 09-21-2012, 07:32 PM
vinniekq2's Avatar
nice moderate combo,sounds like fun,,,
street car?
Old 09-21-2012, 07:34 PM
Daubers's Avatar
Apprentice
street car?
Yeah gna be street. Got it set up for track
Old 09-21-2012, 07:40 PM
vinniekq2's Avatar
try those plugs and go do some 12 second passes
Spark Plug Application SBC thinwhiteduke Engine 3 07-16-2012 04:07 PM
bad spark plug wire/ sbc vetteman2 Engine 4 04-11-2011 11:48 AM
Spark plug selection SBC Phase 2 Bowtie HD karfever Engine 1 02-01-2011 07:04 PM
Spark plug recommendation for 6-71 SBC XNTRCI-T Engine 4 04-11-2006 10:20 AM
SBC Spark Plug Suffix Question. FBody Electrical 1 09-07-2004 04:27 PM
