Spark plug misfiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2013, 08:19 PM
I have an 08 chevy impala, i changed my spark plugs and now its misfiring. Can anyone let me know why its doing that, i had oldschool cars changed those plugs and they run like new, can anyone tell me whats wrong?
Old 01-30-2013, 08:52 PM
DoubleVision's Avatar
Did you drop any?
Old 01-30-2013, 09:25 PM
killeratrod's Avatar
what plugs did you buy, also you may have broken a wire !!
1
Old 01-31-2013, 10:09 AM
I've checked them with a plug tester and everything is fine. I was thinking, could the coil be weak or is it the timing
Old 01-31-2013, 10:44 AM
What engine do you have 3.9 or 3.5? You may have gotten a bad spark plug. Pull one wire off at a time to see if there is any change in the way the engine idles. If you pull the wire off the plug that is bad there will be no change in the way the engine runs.
Old 01-31-2013, 10:49 AM
timing does not change from changing your plugs. I asked what type of plugs to see if they were cheepos. like cdminter59 says check the plugs. Also are you sure you have the wires correct and on tight.
Old 01-31-2013, 04:08 PM
T-bucket23's Avatar
Wiki Edits: 26
What brand plugs. If they are Bosch, throw them away and get some AC's.
Was it misfiring before you changes them?
Chet
89 5.0 H.O. spark plug wireing/spark order psikpa Modern Electronic Engines 6 05-11-2012 08:01 PM
Spark plug wires jumping spark STATUTORY GRAPE Engine 4 10-04-2009 05:14 AM
Spark Plug help... baddbob Engine 14 04-03-2007 06:31 PM
What's the best way of checking for a misfiring plug Jag Daddy Engine 21 07-14-2003 10:53 PM
spark plug RodneyUSAF Engine 8 02-28-2003 11:04 PM
