You went bigger on the camshaft, and just a touch on compression. You will need to re-jet the carb richer, by a couple jet sizes, at least. The "very white plugs" says you are running too lean now. The "pop now and then at idle", says you might have a real lean mixture at idle.(possible vacuum leak) Also MSD recommends a plug gap starting at .050 to no more than .060, for their products to operate best. The fuel you are using will play a part in your tune. A spark plugs "heat range" is determined by the engines cylinder temperature. In other words, a "hotter plug" is designed to perform best in higher temperature's, as in a "lean mixture". and "colder plug" would perform better with a richer mixture. The plug does not "burn" hotter, it will just dissipate the heat slower, keeping the plug "hotter". You also changed gears, and converter which is going to have to be close, rpm wise, to the "grind" of the camshaft. |
Thanks carsavvycook ,
compression is 11.5 so i could up the gap to .040 to .050 as msd says for 10.5 to 13 compression ratios I did try re jetting the carb also : 84 /82 , when i removed the rear power valve i went to 90 in back ( 850 dp ). i checked for vac leak and exhaust leaks as well .. none were found , car dies very quickly if i cover the choke area . Iam using 110 oct. fuel . I had a couple people at the track tell me the pop could be a vac leak as you mentioned or something about the fuel igniting with a plug to hot and is creating a hot spot in the combustion chamber and some fuel is unburnt creating that pop , cold fuel , hot exhaust . I just know it don't sound good but yet yet the car runs quite well as long as iam not idle or just slightly above it . I will check the air mixture screws again with the vac gauge but was sure i did it right . I can only think of plugs after i check that , I guess since the plug now is a hot plug i could try one or two steps colder . The being lean iam afraid will hurt something . |
I forgot to add. Everything on your "tune-up" is going to change with the air temp, and humidity,= barometric pressure, at the time you run. On a cool evening you may have to drop a "heat range", or possibly a "jet" size or 2.
What you need to find is a "happy medium" to start with, with this new engine. Good luck, and Gods speed. Go get em! |
Check your exhaust temps at the header ports of each cylinder. An infrared hand held unit with a lazer pointer works good. You will be OK between 650 and 850 at hot idle with your set-up. At higher rpms you would want it no more than 1350.
sparkplug no longer available
Here is a pretty good site on plugs. It May help you pick a heat range for your engine.
http://www.autohausaz.com/html/spark...lug-wires.html |
heres a cross reference for your plug
http://www.sparkplugs.com/results_cr...CrossWarning=1 |
Question..
A hotter plug than required is detrimental in that it retains heat which can lead to expensive problems in a motor. A plug that is in the too cold heat range fouls easier as the heat from the plug is transferred too quickly to the cylinder head. With this reasoning, I would believe that it would be worse to have a "too hot" plug in a lean condition than it would be to have a "too cold" plug. |
| Spark Plug brands question | Francis | Engine | 65 | 07-15-2008 12:01 AM |
| Top of spark plug broke off!! | HotRodMan | Engine | 7 | 03-06-2008 09:13 PM |
| Spark Plug Tech | ChevelleSS_LS6 | Engine | 17 | 06-28-2006 08:45 AM |
| SBC Spark Plug Suffix Question. | FBody | Electrical | 1 | 09-07-2004 03:27 PM |
| spark plug gap on BBC | ratlover | Engine | 1 | 06-06-2004 05:53 PM |
