Spark plug question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2010, 05:31 PM
Spark plug question
I bought a car with a 1960 390 Cadillac engine. The plugs are a little sooty (black,but dry) so I thought maybe I would go with a higher heat range. The book calls for AC 44 so I bought AC45. BUT the plugs that are in the car are Champion RJ12YC which does not cross reference with AC44. AND the champs have a longer reach electrode. I'm wondering if this longer-style plug was used for a reason,or just a mistake--Would there be any advantage using a longer reach plug?
Old 09-25-2010, 05:57 PM
techinspector1's Avatar
Wiki Edits: 326
I think I might begin by correcting the problem, too much fuel into the motor. Carburetor needs to be rebuilt, float level and float drop set and fuel pressure checked. What carb is on the motor?
Extended TIP plugs might aid combustion. They won't hurt anything, but be cautious that you don't use a plug with longer THREADS inside the chamber. The threads can glow red hot from the heat of combustion and light off the incoming mixture before the spark plug fires, causing detonation.
Old 09-25-2010, 06:17 PM
The car has 6 97s on it,but runs off the 2 center ones only---thought I'd mess with them over the winter. the plugs that are in it has the same amount of thread. So are you saying that the longer tips might be better for now? Or should I put the AC's in or just clean up the Champions?
Old 09-25-2010, 07:17 PM
Wiki Edits: 326
I'm saying that you should stop trying to crutch the whole mess and fix it. You didn't mention the carb setup when you originally posted, but I'll bet money that the jets are too big and the fuel pressure is way too high. Those old carbs begin blowing fuel past the needle and seat at about 3 psi. Rebuild the carbs, lean the jets, get the pressure under control, then worry about spark plugs.
Old 09-25-2010, 07:36 PM
OK, Thanks
2001 Nissan Altima Spark Plug Wires awbazar Electrical 5 11-07-2010 01:47 PM
Reading AC Delco spark plug heat range. rajsid Engine 8 02-03-2010 03:05 PM
Spark plug cable question DENCOUCH Engine 4 07-26-2009 01:16 AM
Spark Plug question redride Engine 2 07-17-2009 01:08 PM
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
