spark plug question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2013, 01:46 PM
spark plug question
I have a set of 461 dhumps and I've ran 303 autolite plugs in them. I am having issues with plug wire and header tubes coming together. Is there a different plug I can use that is shorter? In our circle track engine we used champion plugs that were mainly for a briggs and stratton but I didn't know how that would transfer to the street. Also can you use the plugs that are made for the beveled plug hole heads?
Old 05-03-2013, 03:07 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
NGK makes a short plug, so does Autolite, look at their racing plug, #3934 for one.
Semper Fi
Old 05-04-2013, 09:10 AM
OLNOLAN's Avatar
Spark Plugs
Rowdy, To answer your question, No, you cannot use tapered seat plugs in the old double hump heads, they require a gasketed seat plug. Accel 8197 is a shorty plug for this application. Nolan
Old 05-04-2013, 12:25 PM
spark plug question
The old pre-71 camel hump heads used a R44 AC Spark Plug. If you cross reference a R44 to a NGK it is a B6S or 3510.
Spark plug question Bart horn Engine 0 02-16-2012 06:52 AM
spark plug question makennoise Engine 2 04-05-2011 09:47 AM
Spark Plug question oldtimercarnut Engine 9 08-08-2010 08:37 AM
spark plug question 3gencamaro Engine 1 04-20-2010 05:35 PM
Spark Plug question redride Engine 2 07-17-2009 02:08 PM
