spark plug reading? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2007, 11:55 AM
runn141's Avatar
spark plug reading?
to inspect the plugs after running the engine, should i run the engine to operating temp. and then rev it to high rpm and shut it off at the high rpm moment? or is that bad for for the motor?
Old 10-28-2007, 12:36 PM
You have to run the engine under full load to get the best reading. A 1/4 mile run or a lap around the track, etc. Shut off the engine immediately after you lift then coast to a stop and read the plugs. You'll have to adjust your routine depending on the type of track and local rules.
Old 10-29-2007, 08:26 AM
Frisco's Avatar
Glad To Be Here
I just want to add that as you shut the engine off you must also put the trans in NEUTRAL as you want no load on the engine. The engine should not continue to turn over once the ignition has been shut off.
Another note is that with the advent of unleaded gas it is more difficult to "read" your plugs.
What spark plug should I run??? Ratoflic Engine 6 05-25-2008 08:18 PM
Spark Plug Tech ChevelleSS_LS6 Engine 17 06-28-2006 08:45 AM
Spark Plug Wire shortage??? TheBreeze Electrical 10 11-04-2005 05:01 PM
Cylinder pressure vs. spark plug gap 70bird Engine 3 05-28-2005 08:25 PM
spark plug getting little spark 72 chevy elcamino Electrical 1 10-19-2003 04:54 PM
