Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Spark Plug reading?
Old 01-05-2012, 09:06 PM
396chevelle's Avatar
396chevelle 396chevelle is offline
Originally Posted by oldbogie
As Cobalt points out the right side looks OK the left is carboned up which could be manifold distribution, excess fuel on one side, engine operating temp too low, this can be a problem with the front two cylinders that see coolant right off the pump so they are cooler than everybody else. A wiped cam lobe and lifter, or simply the plugs that were all rich and dark from early tuning attempts and some just haven't cleaned up yet because they miss or late fire, or a leaking head gasket, a valve leaking oil down a guide, rings not yet sealing up enough. The fuel wet threads can be as much an indicator that the plug is miss-firing as it is seeing a rich mixture.
I'd throw them away, put in a fresh set and run it a while then take a new look and report the results back here. This time keep them in order so you can see if any are on common sides of the intake, or are next to each other, at the front or rear of the engine, etc. This is so we can consider trends if there seem to be any of related or common problems between cylinders.
On second thought I wouldn't throw these plugs out, keep them for reference but don't run 'em again. And don't get them confused with the next set you take out.
Bogie
I'll pull the plugs this weekend and put it a new set. When I pull the new set to see how there doing I'll mark them and let you know which cylinder they were firing in! Thanks for the info. WOT or Cruising speed?
