Spark Plug Reading Help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2012, 05:18 PM
I would like to get you guys oppinion on whats going on here. I have all the links on reading but still a little confused. The cylinder numbers are not correct on the cardboard.
Engine is a mid 80's 350 in a 84 c-10 truck
Engine has 7000 miles on it since rebuild
Spark plugs have 7000 miles on them, used for break in and up until today.
I drive 98% on highway.
HEI ignition,34 total, all in by 3000
Old 09-09-2012, 10:25 PM
Try Multi-Ground plug
The pictures you sent it appears that you need to try a colder plug maybe 1 or 2 numbers colder and also check your air /fuel mixture to make sure it is not to lean. Open highway operation it will run leaner and hotter than city running. This looks like a common cold vs. hot plug.as far as number 5 plug make sure your rings have seated and the rebuilder did not get the rings all in line where you are seeping oil into that cyclinder because it looks like that cyclinder has oil in it. Pictures can be deseptive. I hope this helped.jessedenny47
Old 09-10-2012, 05:47 PM
Here is some more pics of the number 1 and 2 cylinders. I drove the engine about 100 miles today and floor it about 5 times. These two were the worst of them all.
Cylinder 1 (Looks like it has small specs?)
Cylinder 2
Old 09-10-2012, 07:21 PM
Richiehd's Avatar
JS-70
Did you richen it up and go to a colder plug? Looks like preignition on that one plug with the dots. 1 step colder, 2 sizes richer all around.
Check your total timing
Old 09-10-2012, 07:34 PM
No I have not done anything to it . I did use a better set of wires this time and not the cheepies. My total timing is 34 degrees. The plugs in the initial photo might not be so good to go by since they were used for the engine break in?
Old 09-10-2012, 07:51 PM
plugs looking better
hay there your plugs are starting to look better. The one still looks like a little colder plug might finish the job. I think if it was preignition you would sure have valve ping. in pulls or hard acceleration. I would run the plugs a little longer to see if they brown up. You want a brownish color no deposits and no blistering. Hope this helped. Jessedenny47
Spark Plug reading? 396chevelle Engine 15 03-07-2012 03:31 PM
Spark Plug Reading! 1987Firebird Engine 1 11-24-2011 03:44 PM
Reading AC Delco spark plug heat range. rajsid Engine 8 02-03-2010 03:05 PM
spark plug reading? runn141 Engine 2 10-29-2007 08:26 AM
Help...Spark plug reading Slant3 Engine 12 09-18-2004 07:00 AM
