Spark plug recommendation for 6-71 SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2006, 12:10 PM
XNTRCI-T's Avatar
AKA Lee in KC
Just getting back into hot-rodding after a 30-year hiatus!!! Building a Chev 355 with a 6-71 blower using World S/R Torquer heads, KB blower pistons (8.5:1), Comp 224/226/112 "blower" cam, MSD 6AL & billet distro, 2x Edelbrock 600s re-jetted for the blower. World Products tech sheet says I need taper-seat 5/8" reach plugs. Blower supplier says I need to go 1-2 heat ranges colder than "normal" on the plugs. That's it! That's all I have to go on to pick plugs! The counter monkeys at the big box parts stores are no help cuz I can't give em a year-make-model to plug into their computers (motor is going into a T-bucket).
A little guidance would be appreciated!!
Old 04-10-2006, 01:18 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Welcome to the site. Your T sounds interesting. Hope this brings this thread to the front page long enough to get you some answers.
Old 04-10-2006, 06:18 PM
i would recommend NGK # r5673-8 or r5673-9. The -8 is one step hotter than the -9.
Old 04-10-2006, 07:07 PM
automotive breath's Avatar
Originally Posted by XNTRCI-T
... Blower supplier says I need to go 1-2 heat ranges colder than "normal" on the plugs. ...
http://www.autolite.com/pdf/HeatRangeFacts.pdf
http://www.autolite.com/pdf/Autolite_HP_Apps.pdf
http://www.autolite.com/pdf/RacingCrossRef.pdf
Autolite AR23 is a good starting point
Old 04-11-2006, 09:20 AM
XNTRCI-T's Avatar
AKA Lee in KC
Thanks for the help, guys!
Spark Plug Tech ChevelleSS_LS6 Engine 17 06-28-2006 08:45 AM
Cylinder pressure vs. spark plug gap 70bird Engine 3 05-28-2005 08:25 PM
Spark arcing outside the plug?? 85MonteSS Electrical 16 11-16-2004 10:02 PM
What heads for a 350 have the spark plug wires on top? batman09 Engine 13 09-25-2004 10:52 AM
Oil Galley Plug Under Rear Main on SBC??? camaroman7d Engine 16 02-19-2004 02:30 PM
