Spark plug removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2013, 11:09 AM
Camaro820's Avatar
Spark plug removal
Ok so I have a question. As most of third gen camaro and firebird owners know, it's a love/hate relationship we have with them. On my 84 camaro, I need to remove the spark plugs. Problem is, the headers I have, I can't get a ratchet and socket in there to remove the plugs because there is no room between the plug and the headers. I also can't fit a wrench in there because the hex of the plug sit recessed into the head. Now without removing the headers themselves, is there any way to get those darn plugs out?
Old 06-14-2013, 12:22 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Most plug sockets have a hex head on the back, can you get a socket on them and use an open end wrench to break them loose? Or maybe grind two flats on the socket mid-body and use a wrench on it, maybe even shortening the socket? How about making your own trick box end out of a plug socket, cut/weld? Thinking way outside the box here!
Semper Fi
Old 06-14-2013, 12:42 PM
A thing called O-Ratchet is most helpful. The socket is much shorter than a conventional spark plug socket and is driven from the outside by a ratchet handle that is hollow through the head. With this you can slip the socket down the plug then put the handle over the insulator and slide it down to engage the socket, then turn the plug out. Reverse the process to put the new one in.
Bogie
Old 06-14-2013, 01:16 PM
Camaro820's Avatar
Lol that's way outside the box! But it's something I didn't think of! This is why I come on here, to get fresh ideas and advice
Old 06-14-2013, 01:18 PM
Camaro820's Avatar
Bogie
Thanks man! I'll have to try that one too! These things are really bothering me. I put new heads on them and now the car sputters when I'm just cruising but when I get on it, it comes alive! It feels like a fouled plug. Could be something else, but I figured I'd try that first.
Old 06-14-2013, 01:33 PM
Try a SLP Performance 30102 short 5/8" spark plug socket that has a 3/4" hex. The short socket allows the spark plug to pass through the socket and you turn the socket with a 3/4" open-end ratchet wrench or a box-end ratchet wrench. Yes they do make a open end ratchet wrench. Be sure to go back in with platinum center electrode spark plugs so you will not need t check or change plugs for the life of the engine.
This is probably more the details of what Bogie was referring to.
Old 06-14-2013, 03:50 PM
Yeah, you can get on the outside hex of the O-Ratchet sockets with a 3/4 or 20mm box or open end as well as the kit's ratchet handle.
Bogie
Old 06-14-2013, 04:23 PM
Sears #21936, Open end ratchet set, 4 pieces, 8 sizes.... $20
Old 06-14-2013, 06:21 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Yep, too many years in Alaska making do I guess, we are an odd bunch...but it looks like there are real tools out there, good luck.
Semper Fi
Old 06-14-2013, 07:27 PM
Camaro820's Avatar
I'll get right on this tomorrow and I'll let you all know how it goes. Thanks guys!!!
89 5.0 H.O. spark plug wireing/spark order psikpa Modern Electronic Engines 6 05-11-2012 08:01 PM
plug and plug wire removal tcoop Engine 4 10-22-2009 08:01 PM
Spark plug wires jumping spark STATUTORY GRAPE Engine 4 10-04-2009 05:14 AM
98 V6 S10 #3 Spark Plug Removal COUGARPOWER Electrical 6 03-06-2007 08:33 PM
Plug removal questrion ChevelleSS_LS6 Hotrodding Basics 6 02-23-2007 03:39 PM
