Spark Plug suggestions? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2007, 07:43 PM
Hi folks,
I would like to first thank the professionals who give great advice to those of us who have nobody to ask firsthand. I have just finished my engine test stand-the schematics I acquired off Hotrodders.com (thank you very much!). I will post pics that may help others on ideas on building their own. I plan on doing a cam break in tomorrow but I have one purchase left to make, the spark plugs. My question is this: What type of spark plugs should I run? I plan on running good quality pump gas. I don’t know if this info will help so I will provide it anyway…I have a stock short block SBC 350 with a Comp Cam 268H Cam and stock converter. The distributor is a GM HEI with a Petronix rebuild kit, headers and a 600 Vacuum advance Holley. The intake is an Edelbrock Performer and transmission is a T350. The heads are reconditioned old 462 64cc Camel Humps. The car, a 1972 notchback Vega with a 5 lug 7.5 inch rear running a 4:56 gear (I would like to change that out to a more realistic street gear, any suggestions?). Any help would be most appreciated, and thanks in advance!
Jason
De Oppresso Liber!
Old 03-22-2007, 05:55 AM
bondo's Avatar
AC, Delco, R43T sparkplugs.......
Old 03-23-2007, 06:28 AM
Thank you very much...
Jason
What spark plug should I run??? Ratoflic Engine 6 05-25-2008 09:18 PM
Spark Plug Wire shortage??? TheBreeze Electrical 10 11-04-2005 06:01 PM
Spark Plug wire looms and Ram Horn exhaust mainfolds Jag Daddy Engine 6 07-19-2005 10:13 PM
Cylinder pressure vs. spark plug gap 70bird Engine 3 05-28-2005 09:25 PM
Smashed in spark plug tip (internally)and porcelain Hookedontrucks Engine 7 09-14-2003 07:48 AM
