spark plug thread size? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2010, 05:46 PM
Hey guys SBC uses a 14mm plug thread right but what is the pitch I have a 14mmx2 tap and a 14mmx1.5 tap but they both seem too big is the thread a 14mmx1.25 on a SBC?
Old 01-23-2010, 05:52 PM
n_keiser_rat's Avatar
its homemade, and its cheap!!!
are you just cleaning old threads??? if so you can take an old plug and cut 2 or 3 small releafs in the threads kinda like a tap and run it in their with some cutting oil and clean them right up.
Old 01-23-2010, 07:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It's 1.25- DO NOT use a tap to clean or 'repair' the threads. Use a thread chaser.
Old 01-23-2010, 11:48 PM
what about cutting the olp spark plug like a tap???
Old 01-24-2010, 05:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The idea of using fasteners (plug in this case) w/the same threads w/flutes cut into them is an old 'solution' to not having a chaser. Go for it.
This chaser is a cheap-o.
Top of spark plug broke off!! HotRodMan Engine 7 03-06-2008 09:13 PM
Need short spark plug laker160th Engine 7 07-18-2007 03:34 PM
drill torque converter and thread a plug to drain completely murrsue Transmission - Rearend 11 03-13-2007 06:34 AM
Spark Plug thread size? Jag Daddy Engine 5 07-08-2003 03:22 AM
