spark plug wires - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2004, 08:06 AM
spark plug wires
I have a oldsmobile 330 motor and I do not know where the spark plug wires go on the distributor cap--does anyone know which way the go on?--any diagrams or pictures to help me out--I need to get this car running so I can get to work
dying here
Old 03-30-2004, 08:17 AM
Do you mean you need the firing order for the cap?
The firing order is "18436572" and should be on the intake manifold. On the intake manifold the clyinders will be numbered on or next to each intake runner. The cap only rotates one way, all you need to do is find at least where one of the plugs go on the cap.
Old 03-30-2004, 08:19 AM
The top of the intake manifold should have the firing order stamped on it. For instance the chevy is 18436572 ...not sure what it is for your olds.
What your going to need to do is remove the #1 sparkplug and bump the engine around with someone holding their thumb over the spark plug hole. Bump the motor around until the air just starts passing the persons thumb...that should be close to top dead center of the #1 cylinder.
Now you open up the distributor cap and where ever the rotor is pointing is the start of the firing order and that is where you start with the #1 spark plug wire. Now noting the firing order, you continue around the distributor cap placing the next wire on the cap that corresponds to the firing order.
Now on the Chevy motors the rotor turns in a clockwise direction but if I recall my nephews 70 Olds his turned counter clockwise.
Joe
Old 03-30-2004, 08:37 AM
oh boy
so it goes counter clockwise not clockwise on an olds?--ok so I have no idea where the first one starts--there are no wires on the cap right now--I see where the numbers are on the intake manifold but as far as the cap i have no idea where to start
i srewed up and posted this twice i think--but what does bump the engine around mean? Does that mean crank it with a key?
Old 03-30-2004, 08:42 AM
Go to the number 1 cylinder, take out the spark plug, turn the motor over by hand until you feel air coming out( please make sure that it is on the compression stroke and sure your not feeling the exhaust stroke).
Go to the cap, take the cap off, note where te rotor is and turn the motor to see which way the rotor on the distributor turns, this next contact in the cap would be number 1, it's all down hill from there.
If you dont know which way the motor would turn, look at the fan, turn the motor in the direction that the fan would pull air. Turn the motor by the lower pulley.
We can not do this for you, we can only tell you what to do.
EDIT: Do NOT turn the motor by key, use a breaker bar, or socket wrench with a socket that fits the balancer bolt to turn the motor, I think it was 1 1/4 socket, but cant remember.
Old 03-30-2004, 11:00 AM
the dwell was set wrong on the car--I had the wires on right--I am an idiot I must have checked the wires about 700 times last night all the while not even thinking about the dwell--The car is getting towed to a friends shop by AAA in about an hour--hes gonna set the dwell for me--thank god for the free AAA tows
thanks for all your help guys--there is not a better bunch of guys anywhere else
