Spark Plug Wires - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2002, 08:21 PM
bg's Avatar
bg bg is offline
Post Spark Plug Wires
Can somebody give me some expert advice about plug wires????
Just got a ZZ4 355hp engine and want to put some good wire to the plugs.......
Is a 8mm big enough wire to use???????
Thanks
Bg
Old 12-22-2002, 09:01 PM
Skylark_77_455's Avatar
Post
I used the Accel 300+ race wire. Those are great
They have a coating that will not burn on headers and have a really low resistance. They run about
$70 at Autozone. They come extra long so you can
custom fit them however you want 'em and they have red blue and black I believe.
Old 12-23-2002, 07:03 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
I really like the yellow silicone Accel 8.8mm spiral core radio suppression wires. Suppresses radio noise while overcoming the graphite core weaknesses and gives full spark. Only about $55 @ Jegs and Summit. Added bennifit for us early hemi guys is that the straight boots are long enough to reach the plugs in a hemi! They are a great value.
Old 12-23-2002, 09:47 AM
F-1Rodder's Avatar
Post
I would recommend that you get a set that is made for your motor rather than cutting them to link. The socket ends are a real pain in the butt when you have to crimp them yourself.
Old 12-23-2002, 07:03 PM
2x4's Avatar
2x4 2x4 is offline
New Member
Post
I just made some for the ole' camaro (first time ever) and it was fun & cheap!
I got a 30' roll of Taylor 8mm wire ($23 at Summit), MSD plug ends ($9) and a MSD mini wire stripper/crimper ($3). I had enough distributor ends.
Looks & works great. I wrapped the wires around the back of the valve covers, nice & clean. I had doubts about the $3 wire crimper, but its a great tool. I had 5-6' of wire left too, so there is room for error.
Old 12-24-2002, 02:20 PM
Post
I use the accel 8 mm and they work great. No complaints.
Old 12-24-2002, 02:44 PM
crshrmn3's Avatar
Post
I like the Accel 300+, especially if you have clearance problems with headers. The spark plug boot on these wires can be bent to whatever angle you need them to be to clear the headers.
Old 12-26-2002, 10:22 PM
Post
i use 8.5mm msdsuper conductor plug wires and they work great on my 72 mustang
