spark plugs??????????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2007, 01:38 PM
inquiring_mind2's Avatar
a shade tree mechanic
I have a 427 bored .60 over. I have 12-1 compression I am running torco 110 octane. I am using and ngk ur 4 plug. I put new ones in made one pass and 135 246are black 7 8 or a brown color. What is causing this. I am not the best with carbs but if you explain it to me I can figure it out. I think I am running it to rich. But I am not for sure how to adjust it. The carb I am using is a 4500 series dominator 1050. With an victor jr 454 in take. Any help would be greatly appreciated. I am also runing the timming at 38 degrees
Thanks,
Chris
Old 07-31-2007, 02:02 PM
Holder350's Avatar
Auto Parts Professional
Go down in jet sizes...sounds like you need to go down about 2 sizes
Old 07-31-2007, 02:10 PM
Holder350's Avatar
If you think the plugs are to blame try some AC PN# 25 in it.
Old 07-31-2007, 02:16 PM
Thanks,
Chris
To judge how to rejet the carb you need to determine which jets are causing the blackened/rich condition. If you made a pass, came down the return road, grabbed your ticket and putted back to your pit the primaries could be the culprit. If you chopped the throttle and shutoff right after the pass and pulled plugs then it would be fairly safe to assume the secondaries are contributing to the problem. Also make sure it's not an oil related issue. Oil into the combustion chamber can cause a black plug as well. It would concern me that 7/8 are that much different in color, although cylinder to cylinder variations are common. Make sure there is no oily contamination in the intake plenum. You would feel it. Shine a light down the ports as well and look at the valve stems and guides.
Old 07-31-2007, 02:24 PM
do I need to go down two in the front and back?
Old 07-31-2007, 02:46 PM
Holder350's Avatar
You need to find someone who can tune the motor.
Old 07-31-2007, 04:04 PM
I talked to a friend of mine we are going to take care of it thanks for the help
Old 07-31-2007, 04:13 PM
I understand I need someone to tune the motor. But I have gotten good advise and I have learned alot from asking questions on here. I just figured I would learn something new again. Thanks to those who have given advise and have taken the time to explain things. I really appreciated it very much. It just seems like some people don't want to take the time to explain things. If that is the case then maybe they shouldn't reply to the post. Just my opinion. Again thanks to all of those who have given good advise I have learned a lot on here and I imagine I will continue to learn from people on here. THANKS
Oil Around The Spark Plugs?????? 1988ChevyBeretta2.8 Engine 1 03-14-2007 11:47 PM
Chevy 454 Spark Plugs Selection Help leejoy Engine 12 10-02-2006 12:05 AM
motor wont start spark plugs have oil on them 54chevy22 Engine 3 09-11-2006 06:59 AM
HELP! spark jumping from wires to the plugs like crazy (long post)!!!!!!!! Blown72Camaro Engine 8 06-22-2004 08:01 PM
Spark plugs sparking to the side mar10 Electrical 3 07-25-2002 05:51 PM
