spark plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2009, 10:05 AM
spark plugs
I've just changed my electrical system from 6v to 12v. The orig spark plugs are supposed to be a heat range 10. The previous owner had heat range 18.
Does changing to 12v even matter with the plugs? Thanks Joe
Old 09-07-2009, 11:35 AM
BOBCRMAN@aol.com's Avatar
6 or 12 volts will not effect the heat range of your plugs. The previous owner may not have understood heat ranges or was using a hotter plug for an engine with excessive oil usage
how soon can i check the spark plugs SBCfan04 Engine 7 04-01-2009 06:35 AM
Carb issue? (Long) mrevil Engine 13 03-30-2009 05:55 PM
Testing Spark Plugs off of 120VAC? 71gtx Electrical 2 03-10-2009 11:50 AM
Chevy 454 Spark Plugs Selection Help leejoy Engine 12 10-02-2006 12:05 AM
Dart iron eagle spark plugs... killerformula Hotrodders' Lounge 10 09-18-2004 11:33 AM
