spark plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2013, 12:57 PM
Last journal entry: door trim
spark plugs
Need a little advice, my 350 sbc bored 60 over has about 10.5/1 compression. I'm using a set of 486 cast iron heads, old fuelie double hump heads. 202 and 160 valves with a 650 holley and strong but streetable cam. I'm using ACdelco R45s plugs which seem to foul after not too many miles. I was told about the new E3plugs but don't know any thing about them. Wondering if someone else has a recommendation for plugs that will last longer.
I just re-curved the Mallory dist with new springs and the 20% shim that came in the set. Runs pretty good after it warms up but still getting pinging higher rpm. Using Sunoco 93 plus octane booster. thx sc
Old 05-26-2013, 03:57 PM
vinniekq2's Avatar
what is causing the plugs to foul? oil,gas,poor ignition?
Old 05-26-2013, 05:11 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What is the total timing at with the 20% shim?
I'm curious what "about 10.5 c.r.". What is the actual c.r.?
Semper Fi
Old 05-28-2013, 11:27 AM
after taking the plugs out this weekend the tips are dark brown, oil residue on threads when I take them out. The first time i put these plugs in the gap was 035 after checking with some other people who run and motor like mine i set the gap to 044. Idle went up after that so I turned it back to about 950rpm.
Old 05-28-2013, 11:31 AM
the last time we set the timing I believe it was around 36 deg. I had this motor built several years ago but only started using it this spring. car and motor has 65 miles on it. I was told the CR would be 11 to1 but i don't think it that high. I don't want to pull the heads to figure it out now.
spark plugs deno Engine 1 04-03-2007 07:13 AM
blazer has spark at coil and gas no spark at plugs ricksautorestoration Engine 29 02-15-2007 08:30 AM
Spark Plugs fred56 Engine 3 06-05-2006 08:53 PM
Spark Plugs 65Stanger Engine 3 05-10-2006 09:52 PM
spark plugs njbloodline666 Engine 2 09-07-2003 09:04 PM
