spark plugs for 383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2007, 09:54 PM
I have a 383 stroker engine (500+hp) and I'm currently running the Autolite racing spark plugs. After 2000 miles the plugs are carboned up.
Is there a better plug? I don't 'get on' the engine much.
thanks
Old 04-05-2007, 04:09 AM
Pre 1960 most race cars ran hot plugs to warm up and cold ones for racing as ignition outputs were far lower. Try a stock plug for a high comp 350 and if it pings go a range or two colder - trial and error.
If as you say, you don't get up it much you may be better off with 2 sets of plugs. Or a higher output ignition, or a leaner fuel curve. Trial and error again.
Old 04-05-2007, 08:11 AM
bondo's Avatar
I question whether you're running Rich,....... Or loosing Oil,..??..??.....
Oil Around The Spark Plugs?????? 1988ChevyBeretta2.8 Engine 1 03-15-2007 12:47 AM
Chevy 454 Spark Plugs Selection Help leejoy Engine 12 10-02-2006 01:05 AM
motor wont start spark plugs have oil on them 54chevy22 Engine 3 09-11-2006 07:59 AM
HELP! spark jumping from wires to the plugs like crazy (long post)!!!!!!!! Blown72Camaro Engine 8 06-22-2004 09:01 PM
Spark plugs sparking to the side mar10 Electrical 3 07-25-2002 06:51 PM
