spark plugs, changing heat range tips anyone? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2002, 06:29 AM
dmorris1200's Avatar
doesn't play well with others
Question spark plugs, changing heat range tips anyone?
I have a 73 Mustang that I just finished putting an engine in. It's a stock 302c.i. bottom end except for the piston rings and timing chain, but I went with a Summit camshaft .471 lift-218 intake and 228 exhaust duration at .050". I also went with a Performer 289 intake, Holley 600 carb, and a Mallory dual-point distributor. Can anyone give me possible pro's and con's to running either colder or hotter spark plugs?
[ February 17, 2002: Message edited by: dmorris1200 ]</p>
BUILT FORD TOUGH
Old 02-19-2002, 11:27 PM
aka Duke of URL
Arrow
-This- should help you.
Old 02-20-2002, 06:11 PM
Smile
thanks for the link,I knew there had to be more to it than (as long as you're not pinging, you're not to hot), gave me some good reading, been so many years since school forgot some of the simple old school basics
BUILT FORD TOUGH
