Spark plugs; Fact or Fiction - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Fact or Fiction?
Yes, it's possible 4 40.00%
Just another gimmick 6 60.00%
Voters: 10. You may not vote on this poll
Old 04-11-2005, 05:35 AM
Rhansen's Avatar
Footbraker
Saw this on another site, looks to good to be true (40:1 A/F???) but I'm sure there are people here better qualified to make that asessment than I am.
http://www.robertstanley.biz/firestorm.htm
Old 04-11-2005, 06:39 AM
Interesting reading. He may be an expert on spark plugs, but his understanding of his magic plugs raising the red line on the tachometer is way off base. I think that is a valve spring issue, not a combustion issue and most motor men will agree. Also, his thoughts on detonation being caused by unburned fuel/air may be a little suspect. Glowing carbon build up or a glowing thin metal surface in the combustion chamber can cause the early firing of the fuel/air early in the compression stroke. Since combustion chambers have not been changed (optimized) for the much leaner mixture, then you must reduce the amount of fuel drastically to get a 40 to 1 A/F ratio since the amount of air stays near the same. Dramatically reducing the lubricating and cooling effect of fuel in our present I/C design is going to produce some bad results, in my opinion. Thus, I will vote that this may well be more "snake oil" than fact.
Trees
Old 04-12-2005, 08:24 PM
PrimeMover's Avatar
Sittin' on top of the world...
Stanley.. Stanley.... Man! that name sure rings a bell. Isn't he the same guy who was selling 'Cow Magnets' to put around your gas lines durring the 70's gas crunch??
My vote's in
Old 04-12-2005, 11:09 PM
4 Jaw Chuck's Avatar
What a bunch of hoooey. Surface gap plugs were installed in WWII aircraft for gods sake! Heck they came factory installed in late 80's Mazda 13B rotary engines!
Pseudo science that he can't explain, yea rrrrrrrrrrrrrrrright. Notice no independant 3rd party dyno charts to substantiate his claims, next snake oil salesman please.
— Han Solo
Old 04-13-2005, 05:39 PM
hunt101's Avatar
Learning something every day
Last journal entry: Adding some tunes
Here is all you need to know..."STANLEY: How does that happen?
KRUPA: I'm not sure."
The plug is interesting and it might get a better spark, but some of the things he said just seem to be way off. A 40:1 air/fuel ratio just doesnt seem like it would work and not to mention it would make a unhappy engine. If they come out I might pick up a set to try them, but it seems like more of a gimmic.
Old 04-13-2005, 07:55 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
If they do, I'll give them a try also.
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Dart iron eagle spark plugs... killerformula Hotrodders' Lounge 10 09-18-2004 11:33 AM
HELP! spark jumping from wires to the plugs like crazy (long post)!!!!!!!! Blown72Camaro Engine 8 06-22-2004 08:01 PM
Question Performance spark plugs for 98 mustang gt sungho General Rodding Tech 11 08-14-2003 01:00 PM
Spark plugs sparking to the side mar10 Electrical 3 07-25-2002 05:51 PM
