Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - spark plugs and gap
Old 11-21-2012, 08:11 AM
JasonL's Avatar
JasonL JasonL is offline
plugs
Originally Posted by cdminter59 View Post
The 492 heads are the 1970 LT1 heads. You can use AC R45 for street driving. These heads oridinally used AC R44 but they are no longer made. The AC R43 is used for a colder plug when racing. A Champion RJ12YC can be used also. Gap is .035 for these plugs. BTW do not use any AC R45TS plugs if the pistons have domes. The S stands for extended tip and will hit the top of the domed pistons on 11.0+ compression motors.
Thanks for the response. I pulled the plug out and there is a Tapered plug in there and the AC r45 look to be flat plugs. Is there a pic of how to tell the difference of heads? I am not sure what my heads need.
